[ICEM] How to merge a surface to another in ICEM ?
Old   May 15, 2013, 07:21
Exclamation How to merge a surface to another in ICEM ?
badboyz31 is on a distinguished road
I've just imported a model into ICEM CFD and it consisted of curves only. The model can be seen below.
So I can create surfaces from the body and its fins (2 large ones and 2 small ones). But I want to merge the surfaces of the fins to the body so I will be able to mesh it correctly. The fins were not attached to the body since there weren't any point in the model.
What should I do to attach the fins to the body ?
badboyz31 is offline   Reply With Quote
Old   May 16, 2013, 03:06
Javi
FJSJ is on a distinguished road
Iīm not very sure if I understand your doubt. But... if you want to add the finīs surfaces to the body you can "right click" in bodyīs part, where you have the rest of your body, and then "add to part" -> "add to part by selection" and then Itīll open a pop-up and you can choose the entities you want. In your case, surfaces.
FJSJ is offline   Reply With Quote
Old   May 16, 2013, 06:54
Far
Sijal
ICEM surfacing tools may not be as powerful as CAD program. It is better to import your model directly from CAD or do some reworking in designmodeler.
[Commercial meshers] Merge Hexa ICEM ignacio OpenFOAM Meshing & Mesh Conversion 1 May 8, 2013 15:43
surface flow lines in ICEM postprocessing Dimitri CFX 0 July 18, 2007 11:30
ICEM Surface from points cloud ? Guillaume CFX 1 June 13, 2007 14:42
ICEM CFD surface mesh Francesco CFX 1 May 31, 2006 11:09
How can I define a intersection surface with ICEM? BEN EZZEDDINE Anouar CFX 0 November 15, 2005 06:05
