[DesignModeler] Named selections - is there a quick way to do it? |
May 24, 2013, 01:58 |
Marion
Rep Power: 14 |
Hi everyone,
I am a Gambit / Fluent user, and I use Workbench with Design Modeler and Ansys Meshing from time to time for specific projects, especially when the mesh is not too complex (with large, complex meshes I've never been satisfied by the mesh in Ansys Meshing). This time I am carrying out an FSI simulation, on a simple case. And even with this I find it so time consuming. A simple operation like selecting faces for my named selections is very frustrating: 1. click on the face 2. right click - named selection 3. in the Named Selection panel, click "apply" so that the face is actually selected + write a name 4. click on "generate" and then do that again for... 18 faces. Therefore I was wondering: is there a way to avoid clicking on "generate" for each named selection? I really dont see the point of losing time over something like that. But I am not an expert in Ansys Design Modeler, so there may be a quicker way. Thank you, Marion. |
May 24, 2013, 02:16 |
Stuart
Rep Power: 25 |
I find it better to apply the Named Selections in Meshing rather than DesignModeler. Then you do not need to click 'Generate'. Also they are in a sub-branch in the Outline tree so do not make the Outline over populated as you can select the minus sign next to Named Selections. I also find it easier to apply Named Selections on internal objects inside a fluid domain in Meshing rather than in DM.
May 24, 2013, 10:05 |
Marion
Rep Power: 14 |
Thanks a lot siw! This trick does help.
Marion. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
only 1 of many named selections not showing up in cfx pre | mihirbhagat | CFX | 2 | April 26, 2019 04:56 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Named Selections Issue | vitor | ANSYS Meshing & Geometry | 5 | February 7, 2011 14:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
