[ANSYS Meshing] problem volume mesh with STL
Old   June 5, 2013, 10:34
Default problem volume mesh with STL
hadrien calmet
hadrien51 is on a distinguished road
Hi everybody
I try to mesh the volume around a stl, it is a car.
-first I was thinking that with a delauney was ok, creating a box around the stl and meshing the box and adding the stl mesh inside. But it don't work, I can let my workstation running 2 or 3 days but ansys not succeed to fill the volume.
-second using the tutorial of how to import stl (aorte), trim/seg surface, extract curves..... and after curvature/proximity and octree mesh (without forget "close gap") but the result is horrible and with lot of holes.
-third with the 2D mesh method suitable for this case, shrinkwrap, but it don't work neither
I post 2 pictures to show that exist gaps in the original stl, but I almost sure that I am not the only one working with this kind of input with smalls gaps and holes.
any idea or suggestion are welcome
thank you
hadrien51 is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] volume mesh leaking out of the surface, in a multi zone problem premchandpendota ANSYS Meshing & Geometry 6 July 31, 2012 01:36
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
