[ICEM] Hexa meshing of Wind Turbine blade. Help for Newbie please
Old   November 28, 2011, 19:36
Default Hexa meshing of Wind Turbine blade. Help for Newbie please
federvo.mala is on a distinguished road
Hello everybody,
first of all thanks for reading. I really need some help because I am stuck with my project. Please.
So I have been doing a hexa mesh for a wind turbine blade in a slice of air volume(120 deg). I got something, but I don't know if my method is right. I don't have the hub, just the blade.
Basically I kind of followed the 'hexa wing body tutorial', therefore I started creating a box round my geometry, then I split bocks in order to creat a small block around my blade.
Then I created a new part (SOLID) selecting the block around the blade.
After that, I split this last block in more horizontal blocks; each split was created for every airfoil in the blade.
Then I simply associated verteces and edges to curves and points of each (lke a 2d airfoil). See pics.
Is this a right method to do this?
In the pics I showed this method but I only did a few splits of the SOLID block but I did that for every every airfoil.
Thank you very much,
help would be really appreciated as I am really stressing out :S
federvo.mala is offline   Reply With Quote
Old   November 28, 2011, 19:40
Here are the pictures of the final mesh.
Old   November 29, 2011, 05:36
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
split for each airfoil? why?
Far is offline   Reply With Quote
Old   November 29, 2011, 07:25
Hello Far,
thanks for your reply.
Well I thought that putting a split for each airfoil would give me vertices and edges to be easily associated with the airfoil.
is there an easier way?
Old   June 8, 2013, 03:19
CY P
plot is on a distinguished road
hello,I'm doing the similar project of wind turbine.The reference that you mentioned,hexa wing body tutorial,would be very usuful for me .Would you please send it for me ?My Email adress is pcy1037@qq.com
Thank you advace.
plot is offline   Reply With Quote
please help in simulating a wind turbine blade in 6 DOF ????.... usman naseer Main CFD Forum 2 March 10, 2016 02:53
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
Modelling of 2D Wind Turbine Blade (HAWT) Richeom FLUENT 1 August 11, 2010 04:18
Wind turbine blade meshing caohan FLUENT 12 April 22, 2010 10:49
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 10:18
