T Quote:
There are three options to model rotor stator interaction (some more are also added in CFX) 1. Multiple reference frame: (aka frozen rotor ) This model will model turbomachinery simulation in steady state manner. It is accurate and will convecte wakes and other non linearities in flow as it is. But the problem is that it gives you solution for that particular relative position. 2. Mixing plane (aka stage model). It is steady state model. It averages parameters at interface (mixing plane, typically at mid of both components) and it is its strong and weak point. It is strong point in a sense that you need one blade passage from both rows and at design conditions it gives very good solution. But it can not model the wake boundary layer or wake shock effects in downstream component as everything is averaged at interface 3. sliding mesh: this is true unsteady model. It includes all effects you would get in turbomachinery except the approximation you will have due to turbulence modeling. It is accurate but reqires equal pitch on both sides and you may end up modeling the full blade row on both sides and it makes it tough on computer memory, cpu and time it takes to solve. Just to give an example of difference in mixing plane and siding mesh requirements. I have solved rotor stator 3d model with around 1 million mesh nodes and it takes around 12-18 hours to converge. But the 2d case (0.112 million nodes) it takes me around 4-6 days to get meaningful results Quote:
4) yes it is: http://aerojet.engr.ucdavis.edu/flue...e171.htm#20871[/QUOTE] |
Dear -mAx- and Far,
I have been busy working in my thesis during this last month and I wanted to tell you my most sincerelly thanks for your help!! It was really helpful, and with all of your information I could solve all my doubts!! Sincerely, thanks for help the people via internet! It was a pleasure. A greeting! |
we need the file turbo-basic.tur which is used in the tutorial of turbo model. I do not have this file in my gambit help.I will be very thanks for help |
