[ANSYS Meshing] How to pattern a mesh in ansys meshing
Like Tree1Likes
  • 1 Post By jrunsten
Old   June 20, 2013, 07:07
Default How to pattern a mesh in ansys meshing
Pavel Peukert
Paulie is on a distinguished road
Dear CFD-online community,
I have a "part", where a lot of the geometry repeats. So i made a pattern in the Designmodeler. My question is, if it is possible to do such a similar operation for the mesh later in Ansys meshing. And if yes, so how. Because to set the conditions at every volume (body) every time again is very time consuming and also to mark every entity for the condition. Also I expect, that the approach to copy a part of the mesh would be faster than, generate it multiple times again.
I searched the users guide and also the forum here, so I hope not to overlooked some thread. Thanks for Your help in forward.
Paulie
Paulie is offline   Reply With Quote
Old   June 24, 2013, 04:33
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
In ansys 14.5 there is a thing called "object generator" where you can set the same mesh parameters for similair bodies. But this will still result in you meshing all of them and not copying the mesh.
Perhaps you want to import the meshes several times and transforming them in you preprocessor instead?
Paulie likes this.
jrunsten is offline   Reply With Quote
Old   June 25, 2013, 07:04
Default Thanks
Pavel Peukert
The object generator approach, at least saves also a lot of my work time and my clicking hands . And decrease the possibility of a wrong click. Thanks
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine kbhamidipa3 FLUENT 0 November 30, 2012 15:52
Mesh Seeds in ANSYS WorkBench Meshing smcp ANSYS 1 March 12, 2012 13:16
[ANSYS Meshing] Export Gambit mesh into something Ansys workbench meshing can read? amad11 ANSYS Meshing & Geometry 1 February 21, 2012 12:26
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 22:04
[Other] Ansys meshing - periodic mesh for fluent jsm ANSYS Meshing & Geometry 4 September 24, 2010 14:25
