[ICEM] Volute
Like Tree7Likes
  • 4 Post By energy382
  • 2 Post By wadoud31
  • 1 Post By diamondx
Old   December 7, 2012, 10:14
Default Volute
Christoph
energy382 is on a distinguished road
Hey everyone!
I've done several volute hex meshes in the last month.
As I know, how annoying it could be to achieve a reasonable quality, I decided to provide my blocking approach and/or my scrip file to anyone, who's interested
So if you become desperate on trying to make a good blocking, just let me know.....I'll help you out
Far, wadoud31, diamondx and 1 others like this.
energy382 is offline   Reply With Quote
Old   April 8, 2013, 05:48
wadoud
wadoud31 is on a distinguished road
please i have a problem with volute meshing, i need a help
wadoud31 is offline   Reply With Quote
Old   April 9, 2013, 06:52
Default volute meshing
wadoud
i want generate a hex and tetra meshing withe a good quality
Old   April 13, 2013, 04:54
Default generate a hex and tetra mesh with a good quality
wadoud
I have generated a hex mesh of the volute but I have in the area of cut water a problem and for tetra mesh I could not generate a good mesh.
I want to generate a hex grid and another tetra mesh with prism with good quality
I want how i can generate a hex and tetra mesh with a good quality.
please i need a help.
thank
Old   April 13, 2013, 05:07
wadoud
Old   April 13, 2013, 14:34
nitin bansal
nitinbansal184 is on a distinguished road
CAn you share your tin file
nitinbansal184 is offline   Reply With Quote
Old   April 17, 2013, 04:45
wadoud
thank you for helps it
how i can me with hex and tetra with good quality
Old   April 17, 2013, 10:36
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
take a look at the simon's tip and trick, it has a procedure on how to perform a blocking for a volute
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 18, 2013, 04:53
wadoud
thank you for your reply, i will read it
Best Regards
Old   April 29, 2013, 11:33
Default I wait your help
wadoud
i have problem to meshing the volute please i need your help
Old   July 14, 2013, 09:59
wadoud
hi
I spent enough time to mesh the volute I used icem cfd (see the picture) but I have a problem of the negative element in the area of ​​cut water.
thank you
Best Regards
Far and Avite like this.
Old   July 25, 2013, 04:42
wadoud
hello
I used to icem cfx14.5 realized this mesh but I have the message of negative Elements in cfx pre at the area of water cut my question is:
how to avoid this problem (the complexity of the geometry) and how to avoid inverted blocks
thank you my friends
Old   July 25, 2013, 10:59
diamondx's Avatar
Ghazlani M. Ali
sometimes you can't really do something against the complexity of the geometry, you then have two choices:
Change it in a more simplified one.
Or go with the unstructured mesh... it's your call
wadoud31 likes this.
Regards,
Ali
Old   July 28, 2013, 06:45
wadoud
hi
thank you my friend for the document, I will try to change the mesh;
best regards
Volute outlet flow into impeller inlet Anthony_impeller CFX 4 December 13, 2011 16:17
I have a two meshes Impeller and volute tareqkh FLUENT 1 February 18, 2011 01:27
Simulation of a single passage and volute Suzzn CFX 1 January 5, 2010 07:05
tascflow - impeller volute interface abaqus CFX 0 August 21, 2003 13:06
volute geometry definition Derrik Mazzer CFX 2 May 15, 2001 08:20
