[ICEM] Quality problem adjusting grid with y+ |
July 24, 2013, 10:56 |
Andrew Kang
Rep Power: 12 |
I am currently working on the blade.
In order to get y+ to be near 1, I'm working on edge parameter and have really bad quality(determinant) near pressure side of the blade for the height of the first grid to be smaller than 0.014, where it needs to be 0.004 according to calculation. Weird part is, suction side shows no problem even for 0.001 of grid spacing, but for pressure side, even 0.013 causes problem. I'm pretty sure there's no problem with geometry since I drew this geometry in ICEM with really low tolerance(less than 1e-06), and I tried to check association problem, but failed to find any problem. What you see from the picture is that the pressure side of the blade and you see ogrid around the blade, associated to curves. Any suggestion will be really appreciated. (Sorry that I can't upload the files due to license of the geometry) |
Problem with staggered grid on numerical simulation | gtr84 | Main CFD Forum | 1 | February 15, 2012 07:58 |
Display Grid problem | Mohsin | FLUENT | 1 | March 12, 2010 03:45 |
Improve smoothness & quality of structured grid | quarkz | Main CFD Forum | 2 | March 10, 2007 15:26 |
Problem with BC on non-overlapping grid interface | Ori Levin | FLUENT | 1 | August 29, 2006 18:32 |
nonstaggered grid problem | Zhi-Xing Yu | Main CFD Forum | 7 | August 26, 1998 13:22 |
