[ANSYS Meshing] ANSYS Meshing Graphics autohide |
July 24, 2013, 04:41 |
Benedikt
I am using Ansys Workbench 14.5 with Windows 7. Somehow I managed to set the Graphics in Ansys Meshing on autohide. So whenever I activate something else than the Graphics-window, it autohides in the right side. When I activate it, there is, in contrast to the outline for example, no pin to toggle autohide on/off. This problem just appears with Ansys Mesh, in the Designmanager it works just fine. Can anyone help me how to deactivate this autohide? Thanks Benedikt |
August 30, 2013, 06:41 |
Solution
Benedikt
So I found the solution. The worksheet was set to autohide and this sets the Graphics to autohide as well. When I deactivate autohide of the worksheet, the Graphics stays in the foreground.
August 30, 2013, 08:00 |
Thanks.
I will test. |
October 23, 2013, 11:05 |
same problem
ioan
I am having the same issue, using Ansys 14.5.7.
The graphics pane keeps dissapearing when I enter another pane. Can you tell me where the setting to de-activate the auto-hide is, as i think i have tried all the options i can!! Thanks, |
February 18, 2014, 20:42 |
Chang Jia-Ming
View->Windows->Reset Layout
could make it recover to the original view |
February 18, 2014, 20:43 |
Chang Jia-Ming
June 25, 2014, 10:01 |
t s
February 20, 2017, 05:26 |
#8 | |
Solved this with little crazy method.
The reason why Workbench remembers wrong preferences it's because it saves them every time during shut down in some text files. So, we locate some files with current change time. For Ansys 17.1: 1. We went to C:\Users\YourUserName\AppData\Roaming\Ansys\v171 2. Then copied all files from this folder to another place (make backup in case of..) and then deleted all files in all subfolders and main catalog "v171". Only files, we leaved empty folders alive: EKM en-us launcher Mechanica_Report Qt RSM Most of them was text xml files. 3. Then also deleted all files in C:\Users\YourUserName\AppData\Local\Temp After that Workbench restarted with default layout. No more autohiding thing. Quote:
To reset workbench to it's defaults you could delete only files in the core directory: C:\Users\YourUserName\AppData\Roaming\Ansys\v171 Deleting files in subdirectories is not necessary. There are only temporary txt and xml files there with current preferences, Workbench makes them again after next shut down. If you want to restore only Design Space features you could delete DS*.xml files in the core directory: DSAppletBKWin.xml, DSAppletWin.xml Last edited by akeyev; February 20, 2017 at 20:22. |
graphics autohide, mesh |
Ansys Meshing and Voronoi Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | March 15, 2017 14:19 |
[DesignModeler] Ansys Geometry n meshing | Niru | ANSYS Meshing & Geometry | 130 | January 14, 2017 11:44 |
How To save a created mesh file in Ansys Meshing | ashtonJ | CFX | 4 | January 7, 2012 22:04 |
[ANSYS Meshing] Internal Wall in Ansys Meshing | swiss_zhang | ANSYS Meshing & Geometry | 0 | September 28, 2011 07:56 |
Ansys meshing | TypeSpeed | ANSYS | 5 | January 1, 2010 06:31 |
