[GAMBIT] Reg:Modeling of wing tunnel for drag test |
July 23, 2013, 16:05 |
ravi
Rep Power: 12 |
Hello All,
I modeled a wind tunnel(Gambit)to capture the flow around pickup truck., Now when I want to add small adjustments to the end of pickup truck, the object I want to add is something like rear spoiler. I can't create a proper volume to run the flow again. The spoiler is connected through an edge to the body of truck. If I change the connecting area and create a volume, I can't mesh it, as the volume mesh and face mesh doesn't coincide. error1: Cannot create an ACIS body with multiple shells. error2: Check the skews of face mesh. (If I create a volume successfully). |
July 24, 2013, 00:58 |
Maxime Perelli
Rep Power: 41 |
pictures, please
In memory of my friend Hervé: CFD engineer & freerider |
July 24, 2013, 16:05 |
ravi
Rep Power: 12 |
In the following pictures, I considered a basic model for my primary evaluation. If you observe at the end there is small device like a spoiler attached which is the reason I couldn't mesh. Without adding that device, I got little acceptable results to.
Thank you. |
July 24, 2013, 16:07 |
ravi
Rep Power: 12 |
After I add device and try to remesh, I get the error "check face mesh". Volume mesh failed due to improper face mesh.
July 25, 2013, 00:56 |
Maxime Perelli
Rep Power: 41 |
Has your spoiler a thickness, or did you build it as a baffle (surface)?
July 25, 2013, 01:40 |
ravi
Rep Power: 12 |
It has thickness. It is not exactly spoiler but a substitutional device we found through research. But very minimal thickness. Almost 2mm thickness .
July 25, 2013, 01:47 |
Maxime Perelli
Rep Power: 41 |
then you have to split your domain with each surface from your device.
Doing this, you should see the device as hollow (just like your truck). But as your geomtry isn't so complex, maybe you could restart from "0": Merge truck and device volumes. Substract this result from your outer box. On the mesh side, you could have skewness problem because of this minimal thickness. You just need to apply a size function (thickness as source)
July 26, 2013, 14:56 |
ravi
Rep Power: 12 |
Basically, I tried to split my total domain into two so that I can have fine and coarse meshes. I am still uncertain of how the volume is simulated, if the inner volume is deleted from the outer domain.
3D wing + wind tunnel hexa structured meshing | icemaniac178 | ANSYS Meshing & Geometry | 9 | October 28, 2010 09:37 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 17:33 |
