July 26, 2013, 10:17 |
Two pipe intersection meshing
Peyman
Rep Power: 12 |
hi everybody,
I wanna mesh the two pipe intersection with gambit (hexa elements) but i cannot decompose the volume. anyone could help me? thanks in advance |
July 26, 2013, 14:45 |
Check out
check out the methods in video (online) here http://goo.gl/P2fVU You need M1 type blocking. So just check the blocking in ICEM and try to implement in GAMBIT.
July 27, 2013, 09:08 |
Peyman
Rep Power: 12 |
dear FAR
thanks very much for your helping, if we have multiple tube in the T junction (For example shell and tube heat exchanger), how can I mesh the model with ICEM CFD? |
July 27, 2013, 10:36 |
Where is the in and out of shell? and also for tubes?
Whether you use gambit or ICEM, the blocking strategy would be same. However procedure is different. In gambit you need to decompose volume to get the required hexa mesh. While in ICEM CFD you will use blocking and O-grid to reach the same mesh. Having said that, now I will explain procedure in ICEM (blocking strategy is applicable to gambit as well) 1. create material points Fluid1 and Fluid2 for shell and tubes respectively. For all tubes place separate material point with name Fluid2. 2. If there is some thickness of tubes, place solid in the region for each tube. Will help you in heat transfer calculations in fluent/CFX. 3. Create main block and split at each tube and inlet and outlet pipes. 4. Create O-grid while selecting outermost faces. 5. Convert into unstructured mesh. 6. Select solver and set boundary conditions. Output mesh. |
July 27, 2013, 14:28 |
Peyman
Rep Power: 12 |
hi,
in fact, fluid is flow on the outside of the internal pipes(in the shell). i am trying to mesh the model with ICEM CFD. |
July 27, 2013, 14:31 |
July 27, 2013, 17:49 |
Peyman
Rep Power: 12 |
No, the ICEM CFD seems to be better than gambit.
I will try with ICEM. |
July 29, 2013, 10:54 |
Peyman
Rep Power: 12 |
Dear FAR
I did not succeed to mesh the model with blocking way, if i send you the model, could you mesh it and guide me? thank you for your attention. http://public.fileup.ir/d/2127010/Part8.igs |
July 29, 2013, 17:00 |
#10 |
Peyman
Rep Power: 12 |
hi,
yeah, no mesh inside tube. |
July 31, 2013, 07:32 |
#11 |
Peyman
Rep Power: 12 |
Dear far
did you succeed to mesh? |
[GAMBIT] Meshing 3-D pipe problem | shayan_mv | ANSYS Meshing & Geometry | 7 | August 18, 2012 13:33 |
[ICEM] Subsurfaces inside a meshing pipe | ThomasZiegenhein | ANSYS Meshing & Geometry | 2 | August 9, 2012 09:59 |
[snappyHexMesh] Problems meshing a pipe | U.Golling | OpenFOAM Meshing & Mesh Conversion | 2 | November 30, 2010 05:24 |
[GAMBIT] 3D mesh for pipe intersection | pranab_jha | ANSYS Meshing & Geometry | 3 | May 28, 2010 01:33 |
Meshing of circular pipe in CFX-mesh | Fatnes | CFX | 3 | March 27, 2009 06:29 |
