[ICEM] ICEM ignores curve mesh number
Old   August 8, 2013, 19:04
Default ICEM ignores curve mesh number
Syavash Asgari
syavash is on a distinguished road
Dear Friends,
I am trying to create a 2d tri mesh in ICEM. I have created an initial grid but when I try to increase node counts, ICEM simply ignores it overriding it by previous counts. I have tried to delete entire elements and nodes but it does not make any changes. My steps are as follow:
1-"Curve Mesh Setup" and setting node counts.
2-"Global Mesh Setup"-->"Shell Meshing Parameters"-->patch dependent option
3-Compute Mesh"-->"Compute".
As you can see, I am a newbie in unstructured mesh and I appreciate any help.
Thanks
syavash is offline   Reply With Quote
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
varying curve mesh spacing at icem surface-mesh? mirko_r ANSYS Meshing & Geometry 6 January 14, 2010 13:23
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
