July 20, 2016, 11:11 |
How to arrange edges when using Ogrid
M F
Rep Power: 9 |
**I got more and different problems and started a new thread. So you don't have to reply here. Thanks!**
Hey there, I'm trying to mesh a round plate with an angle of 30° in a fluid. There's also a cylinder in the fluid but that shouldn't matter in that case. I made a few slices and used the ogrid-feature in the blog with the round plate in it and associated the edges of the inner block with the plate. That worked pretty good. But I'm not quite sure how to arrange the diagonal edges to become a fine mesh. In the picture you can see my try. It got much better than in the beginning but I don't have a real plan how to proceed the improving. Sometimes I move verticies and it gets better and then I do the same thing at an other edge and it gets worse. I hope someone can help me with information about good arrangements. Thanks in advance. Last edited by ma.; July 22, 2016 at 09:33. Reason: new problem |
arrange, edge, ogrid |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
