[ICEM] Generation of geometry and mesh automatically |
August 2, 2013, 06:35 |
Ravikiran Anapagaddi
Rep Power: 12 |
Dear All,
I would like to generate the geometry (.tin) and mesh generation (.msh) automatically using Ansys ICEM for CFD simulations using Ansys-CFX by writing any code. I mean to say that, If user gave the dimensions of the geometry, then code should generate .tin and .msh file for simulations. Can any one help in this? Thanks and Regards, Ravikiran |
August 12, 2013, 08:37 |
Replay Script
venkatesh
Rep Power: 13 |
You can record the commands using reply script
Before you start creating the geometry, go to File > Replay Scripts > Replay Control have a look on this link to understand how the scripting is done http://www.youtube.com/watch?v=tYrbScUH9RE Are you going to do optimization? If that is the case, you can use matlab or any other programming language. If you are going to do in Matlab, you should write a function in matlab which calls the ICEM CFD and execute the replay script. |
August 12, 2013, 08:45 |
Rep Power: 12 |
Dear Venkatesh,
Thank you for your reply. I have got the methodology of programming in ICEM. Now I am writing script for auto-mesh generation and CFD simulation. I am writing in fortran code. Thanks and Regards, Ravikiran |
August 12, 2013, 08:53 |
venkatesh
Rep Power: 13 |
Hi Ravikiran,
I have done it in Matlab. Sorry I done know how to do that in Fotran. Hope some one will give you a better suggestion. |
August 12, 2013, 09:02 |
Rep Power: 12 |
Thanks alot. Can you please share your matlab files if you can. So that it will be useful further. Mail id: rkiranmat@gmail.com
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
