[GAMBIT] import many vertices into gambit bue not in normal way |
August 19, 2013, 02:25 |
Rep Power: 12 |
hi
I'm working on some airfoils and i must create airfoil and this is awful to make a airfoil by gambit ...however i heard that i can work with the file that has the Suffix ".jou" anybody know that how is it working?or another way? THANKS |
August 19, 2013, 03:26 |
Maxime Perelli
Rep Power: 41 |
is your airfoil 2d or 3d?
In memory of my friend Hervé: CFD engineer & freerider |
August 19, 2013, 03:31 |
Rep Power: 12 |
my airfoils are 2D!
August 19, 2013, 03:41 |
Maxime Perelli
Rep Power: 41 |
did you try to create edge from vertices?
http://aerojet.engr.ucdavis.edu/gamb...e_create_nurbs Else you can create an edge with 2 vertices and so on..
August 19, 2013, 03:42 |
Paritosh Vasava
Rep Power: 22 |
You can always import CAD models in gambit. And yes it is possible with the journal file. But then you have to either write the journal file manually or make a program that created the journal file.
August 19, 2013, 03:57 |
Rep Power: 12 |
vasava
I try to change journal and i put my vertices coordinates like this file below...but it did not work! and i also worked a little with solidwork and catia but i could not to do this work fast..however i want to learn it and i just make 10 airfoil that its take 2 hours!it doesnet matter i want to learn it... Thanks default_id4592.zip |
August 19, 2013, 04:02 |
#8 | |
Maxime Perelli
Rep Power: 41 |
August 19, 2013, 04:05 |
Rep Power: 12 |
they are different.
August 19, 2013, 04:13 |
Maxime Perelli
Rep Power: 41 |
As vasava mentionned, you could handle it with journal, but it will ask lots of time.
(once you created your vertices, then you need to get edges, and surface) I would create the 2d shape with cad package, and then import it in Gambit.
August 19, 2013, 04:55 |
#11 |
Paritosh Vasava
Rep Power: 22 |
I suggest that first you try creating something simple with journal file. Make sure it works and also make sure you understand how the journal files work. Once you are confident then you can gradually change gears.
I also suggest you go through some gambit tutorials. Especially the ones that includes even the smallest step like creating edges and vertices. While doing so notice the message window. That's the way I learnt to write journal files. All the best!! |
August 20, 2013, 04:15 |
#12 |
Rep Power: 12 |
thanks
it is hard but i search for it i also heard that i can with Excel with gambit..i go to do it..if anyone know that help me |
Gambit Import error | GUEST | FLUENT | 7 | May 30, 2019 11:46 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
SketchUp 3D model import to Gambit or Fluent | Steve Johnson | FLUENT | 0 | February 8, 2009 14:21 |
IMPORT TO GAMBIT | IVANRIPS | FLUENT | 1 | June 19, 2008 15:29 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
