[ICEM] Mesh airfoil with suction holes in ICEM CFD |
August 26, 2013, 15:24 |
Rijas
Rep Power: 12 |
I want to mesh airfoil domain with variable no. suction holes in ICEM CFD, i.e. each time different holes will exist among the circles in the geometry(image attached). Is there any easier way of doing it instead of creating a block for each circle separately.
August 26, 2013, 17:31 |
You can use hybrid mesh method to creat two domains.
FIRST ONE: outer domain which will contain the domain around around foil and it will be unstructured domain. SECOND ONE: Inner domain around airfoil which will use blocking method th capture the geometry of the airfoil. or you can make all the domain unstructured and use prism layer to capture the layer around the airfoil which the boundary layer is effective. There is a hybrid mesh tutorial you can find it here http://www.4shared.com/rar/l3vcINz_/...dairfoil.html? I didn't make this tutorial and all the credit goes to the person who made it, i just can't remember where did i get it. regards |
[ICEM] ICEM CFD: STL surface mesh to volumetric mesh | a.sarami | ANSYS Meshing & Geometry | 0 | August 20, 2013 10:32 |
Icem CFD mesh grading issue | joegi.geo | ANSYS Meshing & Geometry | 7 | March 8, 2011 18:26 |
Hybrid mesh in 2D in ANSYS ICEM CFD | Alex | CFX | 6 | March 5, 2011 16:32 |
ICEM CFD Airfoil Tutorial Input | Tom | ANSYS Meshing & Geometry | 1 | September 25, 2009 06:50 |
prob while exporting icem cfd hexa mesh to fluent | mani | CFX | 4 | March 7, 2007 03:41 |
