August 31, 2013, 07:31 |
problem with blocks
Pawel
Rep Power: 12 |
hi,
can someone little help me? how should i change block to get better quality of mesh? thx a lot for advice |
August 31, 2013, 15:16 |
why don't you give a try to the extrude blocking command?
September 1, 2013, 08:41 |
Pawel
Rep Power: 12 |
ok i will try, but first i will have to learn how to use it. I start using icem few days ago. Thx for help,
it's again me. I can't find any tutorial or information how to use extrude. When i try to use it, i allways get some error..maybe someone know turial or video how to use it. i try to mesh my profile in 2 diffrent way, but i still get bad element. Last edited by pawel_sag; September 1, 2013 at 16:32. |
September 2, 2013, 06:12 |
Javi
Hi Pawel,
If you want to create a surface between those two pipes you have to do: 1º - Create a representative curve of the surface to extrude. Go to Geometry -> Create/Modify Curve -> Concatenate/Reapproximate Curves and choose the two curves (in Fluid_2 or Fluid_3) to form a circunference. 2º- Create a drive curve. Go to Geometry -> Create/Modify Curve -> From Points and select one point in Fluid_1 and other point in Fluid_2. 3º- Create extrude surface Go to Geometry -> Create/Modify Surface -> Curve Driven and select the curve created in third step and circunference created in second step. aaextrude |
September 2, 2013, 12:51 |
Pawel
Rep Power: 12 |
i don't know how to create proper mesh for pipe with shutter.
September 2, 2013, 12:57 |
if you don't mind it'd be more helpful that you share the *.tin file.
regards. |
September 2, 2013, 13:05 |
Pawel
Rep Power: 12 |
thanks you for all of your help and replies
September 3, 2013, 15:29 |
dear pawel,
first of all, i did a little modification of the geometry you provided in order to have a guide curve along the pipe of your model. i added also some points that may serve as reference to the blocking. i suggest you to start with a 3D blocking by selecting appropriate entities and also the desired options, for instance "project vertices and orient with geomtry". to initialize the first block you can select the entities (curves) shown in the picture below to obtain a block aligned with the corresponding section of the geometry as depicted in the next figure. after this procedure, you'll be able to use the command "extrude along curve" to generate the blocking for the rest of the geometry. please take care of the options "twist per layer" and "number of layers". i came up with a topology (approach2) in which i obtained the premesh shown in the following picture, however, using the approach2 the region of the shutter cannot be meshed due the position of this one. it'd be easier to do using the approach1. here are the geometry and blocking files. regards. César |
September 4, 2013, 05:51 |
Pawel
Rep Power: 12 |
Thanks you helped me a a lot
Now I have a problem with Fluent, any advice for this simulation? i try using model K-epsilon (Standraed, rng, realizable) and k-omega (sst). Which algoritm is best ? Simple? or i have to try all of them and find the right one? |
September 4, 2013, 08:12 |
#11 |
you still have to deal with the meshing of the shutter.
September 4, 2013, 10:00 |
#12 |
Pawel
Rep Power: 12 |
now i have something like this, there still bad elements but i will try to fix them
September 4, 2013, 13:13 |
#13 |
i can't see very well the behavior of these bad cells. please show more closer views. are you using o-grid?
September 4, 2013, 14:13 |
#14 |
Pawel
Rep Power: 12 |
yes i use it, maybe i did something wrong.
i add file with my actual version |
September 4, 2013, 15:43 |
#15 | |
pawel,
you did the blocking in the wrong way. as i see from your actual version, you're sticked to the pattern of your first topology (i.e., trying to match the blocking with the geometry through horizontal and vertical splits). i also see that you didn't use the "extrude along curve" command since your actual version of the geometry lacks of a curve describing the path of the pipe. check the blocking files that i provided you and compare them with yours, specially in the region of the twist of the pipe. you'll see the difference in the blocking and behavior of the mesh. also, revise again the above suggestions and pay attention in the part: Quote:
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
