[ICEM] 3D Meshing help needed for novice!
Old   September 12, 2013, 13:13
Default 3D Meshing help needed for novice!
Fergus
fmcc789 is on a distinguished road
I went to a course on Fluent and their alternative meshing program, but I have now found out for my purposes, ICEM is much better. Sadly I am not at all familiar with it!
My situation is that I imported an STL file of a 3D locust head in to ICEM CFD. It has a very uniform nice faceted surface so I have converted this directly in to a mesh using the Edit > 'Facets -> Mesh' option. I also imported a large cuboid to act as my fluid region and I have lined up the locust head inside this, with the aim being to analyse flow over this whole model (nothing inside the head..)
I have defined parts on the fluid region for 'Inlet', 'Outlet', and 'Wall'
I have also used 'Create Body' and using material point option I selected relevant points for the fluid region and separately for the locust head.
So, to make things clear, in the control tree, I have 'Inlet', 'Outlet', 'Wall', and 'Head' under parts, and also have a Mesh > Shells entry because I converted the facets to mesh.
Now I have several questions:
1. Do I now delete the head geometry (to just retain the head mesh)?
2. How do I create a volume mesh for my fluid region? When I try and mesh anything, it just builds up a volume mesh inside the HEAD, with nothing in the fluid region. I don't think I even need a volume mesh inside the head, is that correct?
Any help is greatly appreciated, apologies if any of these questions seem terribly stupid!
Many thanks in advance,
Fergus
fmcc789 is offline   Reply With Quote
Old   September 12, 2013, 13:15
Fergus
I should also add, I also don't have a surface mesh on the fluid region either, and would also appreciate any help in achieving this first!
fluid volume, icem 3d
Beginners Guide Needed: Meshing. charltonjames STAR-CCM+ 8 November 7, 2017 02:23
[ICEM] Help needed regarding meshing of T junction selvam2487 ANSYS Meshing & Geometry 0 February 25, 2013 04:27
[GAMBIT] Help needed with meshing! fluentnoob ANSYS Meshing & Geometry 24 June 6, 2009 17:41
Marine current turbine (meshing and stimulation help needed!!) coolyihao FLOW-3D 0 March 16, 2009 11:48
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 09:18
