[DesignModeler] Region marking?
Old   October 11, 2013, 08:04
Default Region marking?
vExus is on a distinguished road
I am wondering if there is a possibility to mark a part of body/part in DM to use it later as a register to patch in FLUENT?
For example. I have 1 body consisting of 1 part. I want to mark 3 different regions of these part so that I can patch them with different initial temperatures. Is this possible? How to do it?
vExus is offline   Reply With Quote
Old   October 11, 2013, 08:42
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Select the surfaces, right click, and create a Named Selection.
jrunsten is offline   Reply With Quote
Old   October 11, 2013, 09:09
Thats not what i am talking about.
Using Registers
The ability to patch values in cell registers gives you the flexibility to patch different values within a single cell zone. For example, you may want to patch a certain value for temperature only in fluid cells with a particular range of concentrations for one species. You can create a cell register (basically a list of cells) using the functions that are used to mark cells for adaption. These functions allow you to mark cells based on physical location, cell volume, gradient or isovalue of a particular variable, and other parameters. See Chapter  23 for information about marking cells for adaption. Section  23.9 provides information about manipulating different registers to create new ones. Once you have created a register, you can patch values in it as described above.
Taken from: http://combust.hit.edu.cn:8080/fluen...ug/node799.htm
The question is: can I mark a part of 3D body to make it a register in FLUENT?
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
