August 3, 2012, 04:29 |
Export Mesh To Ansys_Error message
Rep Power: 13 |
Hi all,
I try to export a certain mesh for use in ANSYS Fluent but I always get the error message "An internal error has occured: invalid command name "aie_ansys_file" ". Could anybody help? Thanks in advance and regards, Zelle |
April 22, 2013, 08:09 |
Anne Gerdes
Rep Power: 15 |
I have the same issue, have you found a solution for this problem?
February 25, 2014, 06:00 |
Hi there
I have the same problem - did you two find a sulution to this problem yet?
November 12, 2014, 01:20 |
[ICEM] Export Mesh To Ansys_Error message
Hardik Ramani
The mesh is not directly export by export mesh option.
For that first of all you have to select output tab and select output solver as Fluent and then u can write mesh file as output. |
error message, export, invalid command name, mesh |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Export 2D mesh from ICEM to Fluent | BuilttoSpill | ANSYS Meshing & Geometry | 4 | August 28, 2010 08:16 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
2D mesh export of an original 3D model | Yogendra Shastri | Main CFD Forum | 0 | February 22, 2008 13:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
