Script Commands
can someone tell me, how the following commands work and can give me an example for them? 1) ic_geo_project_point I don't really understand how this command work.2) ic_geo_nearest_object 3) ic_geo_cre_bsp_crv_n_pnts_cons Always get this error message when i try to use this: |
Hi Tobi,
maybe this links (posted by Far) can help you in your answer :) Scripting lenguage version for ICEM 14.0 on win 7 64 bit |
Hi Javi,
thank you for your answer, but I already found these links and they don't help me, because it's the same that is in the ICEM help. |
Hi Tobi,
Here's a code that gets the nearest surface at given coordinates, renames the surface and create a part that contains only the surface. Load the code in Replay Control and run it to see how it works (and turn on Show Surface Names): Code:
# close geometry |
and the ic_geo_nearest_object function seems to work only for surfaces, for example to find the nearest surface at coordinates {0 0 0}: ic_geo_nearest_object surface {0 0 0}
The ICEM CFD Programmer's Guide: so incomplete...:confused: |
