October 17, 2013, 08:11 |
Meshing container
Hello.
I have a problem with hexa meshing of the container that is presented in the pictures below. I have no problem with meshing when the top and bottom of container are flat surfaces. But now, that I am trying to do it with curved surfaces, I am stucked. I tried to block the whole geometry, split it where the curvature begins, and then make O-grid for top and bottom part (I used type of O-grid, as I would mesh quarter of a sphere). But than I couldnīt make O-grid in the middle part of the continer (cylindrical part), so a lot of cells had very bad angles . Is it possible to first make good O-grid mesh in the middle part of the container. There I would just use O-grid for half of a cylinder. And then make the mesh for top and bottom. Or am I doing this totally wrong? If so, could someone please give me some guidelines what would be the most efficient way to mesh this. Probably I should ask this first: Although the geometry is quite simple, is it possible to make a good hexa mesh at all? Thanks. |
October 17, 2013, 17:14 |
Rep Power: 24 |
You can create the ogrid structure in just one step (Pics are attached). You can see the initial blocking, block+face selection for ogrid creation and the resulting mesh.
October 17, 2013, 18:31 |
Thank you very much for your reply.
Display Modes | |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
