October 23, 2013, 08:57 |
Geometry Problems - Cone nozzle
Good Morning
I'm generating one unstructured mesh in ICEM. The process: -- Import from CATIA v5 --Density Box around the geometry --Seed: 4096 / robust Octree / sizes: {geometry 12} {fluid: 1024} {FF: 4096}/ prism layer: default settings --generate --check mesh --Quick Delaunay -- export fluent The problem is that the geometry doesn't seem perfect when I'm pos-processing it. Is that a problem with the unstructured mesh ? The picture shows it: thanks ! Last edited by leo_NM; October 23, 2013 at 08:59. Reason: Images |
October 24, 2013, 22:09 |
Stuart Buckingham
Rep Power: 25 |
For such a simple geometry you could easily use patch dependant or structured.
If using structured, the blocking topology for this is pretty straightforward. Stu |
November 1, 2013, 08:18 |
Thank you guys !
I divided the geometry nozzle in parts and put small sizes for the critical parts. The mesh sizes were too big for that part of the geometry so the elements were distorcing the nozzle. I'm trying to generate the structural grid as suggested too. It is simpler than I thought it would be. Thanks !! |
[ICEM] Problems with mesh for annular-type geometry | Kristin_N | ANSYS Meshing & Geometry | 10 | January 2, 2016 18:08 |
[TurboGrid] Ansys Turbo Grid: Import Geometry Problems | Polito | ANSYS Meshing & Geometry | 1 | July 31, 2015 17:32 |
[TGrid] Import geometry problems | Polito | ANSYS Meshing & Geometry | 1 | October 20, 2013 22:18 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
problems with 2d rectangular geometry | ariereath | ANSYS Meshing & Geometry | 4 | August 18, 2010 11:39 |
