November 3, 2013, 15:19 |
edges parameters
Domenico
Rep Power: 16 |
Hi All,
I am pretty new in ICEM and I am trying to create a boundary layer by considering a specific distribution on the edge parameters. At the moment I am considering a bi-geometric mesh law (see attached figure). The problem is that apparently everything seems to be frozen in the sense that although I try to change a parameter, nothing changes. Do you have an idea what is going on? Many thanks in advance |
November 4, 2013, 15:40 |
Perhaps you have activated the "edge parameters locked" option over some edges of your blocking in the "Premesh params" dialog box showed in the picture.
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
