[DesignModeler] Design Modeller create surface
Old   October 31, 2013, 13:52
Default Design Modeller create surface
Papis
papis is on a distinguished road
Hello people
I have a very frustrating problem with DM.I am new to DM so the obvious is not so easy.
Here is my problem.
I want to create the surface of a wind turbine blade.I have the blade x,y,z coordinates in a structured manner(257 points coordwise 131 strips spanwise)
For importing the geometry I use 3d curves concept
1)I cannot import the whole geometry because maximum points is 10000(that can't be right?).I split the file in 4 different files and it works
2)For each curve an explicit line body is created.At the end I have 131 line bodies.I want to create a skin loft surface.However I must create a separate namespace for each one of my bodies to create the loft.Is there an automated way to do that?Why can't I create a loft from the line bodies(which in my opinion is the obvious).I could use let's say 10 of my bodies(because 131 namespaces by hand is not the best workflow...).Then I would lose the details of my geometry.
3)Is there a way to import a surface from a text file?
I mainly want to use DM as preproccessor for the geometry before importing it into ICEM.Isn't the DM the proper tool for that ?Maybe it would be better if I used a CAD software like Autocad,SolidWorks?
Thank you
papis is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[GAMBIT] How to plot S pipe mariam.sara ANSYS Meshing & Geometry 36 November 7, 2013 15:22
udf to create surface plane (aligned to a surface) Ananthakrishnan Fluent UDF and Scheme Programming 0 May 23, 2013 14:30
[snappyHexMesh] How to create a separate patch on a blockmesh surface bing.guo OpenFOAM Meshing & Mesh Conversion 0 April 24, 2011 11:35
How to create square surface mesh and volume(ICEM) Areriko CFX 3 July 16, 2007 03:38
