November 1, 2013, 02:57 |
3D Model Meshing Issues
Ikhsan
Rep Power: 12 |
hi.
i intend to mesh a 3d coldplate with fins, along with 6 thermocouples drilled at each side. the mesh size of each slot should be around 0.1mm as the diameter of the slot is around 1.6mm. how can i mesh the slots with a size of 0.1 but mesh the rest of the model at a larger size? |
November 4, 2013, 01:36 |
Maxime Perelli
Rep Power: 41 |
with the use of size function: https://www.sharcnet.ca/Software/Gam...ide/mg0502.htm
In memory of my friend Hervé: CFD engineer & freerider |
Compressible turbulence model issues | 351Cleveland | OpenFOAM | 5 | October 24, 2013 15:41 |
[ANSYS Meshing] ANSYS Meshing hangs at "Preparing to model boundary for part" | jonny_b | ANSYS Meshing & Geometry | 12 | June 12, 2012 01:55 |
ICEM: Projectile Meshing and Modelling Issues | gman89 | ANSYS | 0 | May 11, 2011 23:01 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
