[ANSYS Meshing] Meshing around sharp trailing edge in CFX
Old   November 7, 2013, 23:11
Default Meshing around sharp trailing edge in CFX
Tom
ttu004 is on a distinguished road
Hi Guys
Could anyone tell me how to make the inflation around the sharp trailing edge of an airfoil without letting them skewed? (as shown in the figure below).
As my intention is to capture turbulent flow inside the near wall regions of an S814 airfoil, I have set the first cell height to 0.000014 m (y+ = 1) and the turbulent boundary layer thickness to 0.0116 m (using flat plate theory) by using the First layer thickness method. (maximum layers: 28, first layer height: 0.000014, growth rate: 1.2)
However, with this defined inflation control cells around the trailing edge (sharp tip) become highly skewed. And I believe that this is the reason that the computational results (lift/drag coefficients) are diverging from the experimental validation.
Thanks for any suggestions or advice
Tom
ttu004 is offline   Reply With Quote
Old   November 8, 2013, 02:21
siw
Stuart
siw will become famous soon enough
You may want to increase the maximum angle to 180 (the default is 140). This is found in the global inflation details by setting the advanced option to ON.
What have you done to cause the inflation layer to only really build up on the leading half of the aerofoil? It looks like the stair stepping collison adoidance is being used. Perhaps fixing that will more likely help with the inflation layers around the trailing edge. Also you may want to increase the cell density at the trailing edge.
Are you using the Pre-Inflation or Post-Inflation method?
siw is offline   Reply With Quote
Old   November 8, 2013, 02:54
Tom
Hi Stuart
Thanks for your advice.
It was really helpful!! As I turn 140 to 180 the inflation resolve the entire edges!!
By the way, I am only using inflation with First layer thickness method and I did not use stair stepping collison adoidance for sure.
Also, I am using pre-inflation for this analysis.
Cheers
Tom
Old   May 30, 2016, 08:16
Default Maximum Angle confusion
Marcel Jay
marcel_jay is on a distinguished road
I have some highley skewed elements near sharp edges (about 120°) and I don't know how to improve the inflation layers. Chaging the maximum angle (anything between 90 and 180°) did not change the mesh. It had to be refreshed but it stays exactly the same.
Any idea? Or maybe it's because I don't even understand the definition of it...
The Maximum Angle control determines prism layer growth around angles, and when prisms will adhere (project) to adjacent surfaces/walls. If the inflated mesh involves extruding from one surface and not its neighbor, and the angle between the two surfaces is less than the specified value, the prisms (sides) will adhere (project) to the adjacent wall.
Cheers
marcel_jay is offline   Reply With Quote
Meshing around sharp trailing edge in CFX ttu004 CFX 1 November 8, 2013 05:48
Meshing of a sharp edge orifice with a radius Moose1231 STAR-CD 3 December 6, 2011 15:32
Trouble with sharp trailing edge Prakash.Paudel ANSYS Meshing & Geometry 4 August 12, 2011 14:01
trailing edge problem Kuo Wei-Jen Main CFD Forum 2 April 14, 1999 10:09
