November 13, 2013, 12:32 |
Cutting faceted surface with plane
Luis
Rep Power: 12 |
Hoping someone can help with what seems to be a simple problem. I'm fairly new to ICEM CFD so please bear with me.
I have imported a set of faceted data into ICEM and eventually I wish to add features to it. However, my issue at the moment is modifying the faceted surface. I would like to cut straight through the surface, I'd assume I would use a plane to do so. But I cant figure out how to do this using the create/edit faceted surface options. Thank you. Luis |
Curiosity & Question about cutting plane through axisymmetric region | aerospain | OpenFOAM Post-Processing | 0 | October 4, 2012 04:05 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 10:45 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
postprocessing - surface - plane | Brujo | FLUENT | 2 | March 1, 2008 10:36 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
