[DesignModeler] How to fit a circle in trailing edge to model each sections of a blade? |
June 10, 2015, 07:14 |
Julia
Rep Power: 14 |
Hi
I want to model a blade in DesignModeler. to do this I follow these steps: 1) use 3D curves to import airfoil's point of each sections of blade 2) use sketch projection to project this points to sketch. 3) use skin/loft to loft this section finally the blade modeling complete but, I need to fit a circle in trailing edge to model each sections properly, but I can't do it. How can I do this? |
blade, designmodeler |
Leading edge and trailing edge of an airfoil rotor blade | Jun_Milan | CFX | 0 | July 10, 2014 23:07 |
[ICEM] ICEM Hexa meshing tutorial - Wing with sharp trailing edge | Far | ANSYS Meshing & Geometry | 34 | October 21, 2013 05:46 |
[DesignModeler] Creating a blunt trailing edge from collapsed leading edge | gmd | ANSYS Meshing & Geometry | 0 | March 2, 2012 09:48 |
Aerofoils/blades with rounded trailing edge. | Sergei Chernyshenko | Main CFD Forum | 6 | July 26, 2000 05:10 |
trailing edge problem | Kuo Wei-Jen | Main CFD Forum | 2 | April 14, 1999 10:09 |
