[ANSYS Meshing] Mirro Mesh deletes translational periodicity |
November 25, 2013, 06:19 |
Hello!
I have some troubles using ICEM. I want to investigate the flow in a compressor cascade. For the first calculations i used a grid, as shown in the attached png.file. problem.jpg Since its an symmetric geometry i just modeled half of the geometry and used a symmetry BC in fluent. For comparioson i want to do the calculations for the full model. Therefore loaded my mesh into ICEm and used: EDIT MESH -> Transform Mesh -> Mirror Mesh copy Merge nodes Delete duplicate elements Reflection : Plane Axis = Z Point of Reflection: Origin The Mesh is duplicated correctly, but the peridoc conditions are not mirrored. When i have a look at: Mesh -> Periodicity it can be seen, that the mirrored part has no periodic elements. Has anyone an advice what to do? many thanks in advance |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] 2D mesh extrusion and periodicity | robboflea | ANSYS Meshing & Geometry | 1 | August 31, 2013 15:34 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
ICEM periodicity nodes after mesh generation... | Andrey | CFX | 8 | May 1, 2012 17:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
