[ANSYS Meshing] mesh conformity failure
Old   December 13, 2013, 09:23
Default mesh conformity failure
eskade1 is on a distinguished road
Hello everyone!
I need to generate a mesh of modified hydrocyclone fluid volume. After creating the geometry in SolidWorks and extracting fluid volume in Ansys DM, then slicing fluid domain and forming a new part, I want to obtain conformal mesh in all interfaces, but I still get non conformal interface in one place. I have already tried various meshing methods, nothing worked.
It is quite important for me, so I attach my files and a screenshot so that You can help me. Thank you very much!
http://img689.imageshack.us/img689/6537/x0vv.jpg
http://www.sendspace.pl/file/e237602b35ab3af2df93950
eskade1 is offline   Reply With Quote
Old   December 16, 2013, 06:23
any ideas?
Old   December 16, 2013, 06:50
vidyanand
Vidyanand Kesti is on a distinguished road
Sorry i am unable see the pictures but please check and do it may it help you please check there should be gap in between the volumes, if found gap you can extrude the faces are can use the solid extrude method
or did you check in DM all are in one part, select all parts and right click-new part
Vidyanand Kesti is offline   Reply With Quote
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
CFX Wind turbine mesh trouble and solver failure tallliam CFX 9 April 29, 2012 22:55
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
