[ICEM] Propeller blade-Shifted periodic or J-Type BLOCK
Like Tree2Likes
  • 1 Post By cesarcg
  • 1 Post By Far
Old   August 9, 2013, 05:50
Default Propeller blade-Shifted periodic or J-Type BLOCK
venkatesh
venkat_aero2007 is on a distinguished road
Hi
I am trying to mesh a propeller blade. I tried to mesh the propeller blade just like the wing. The propeller geometry is shown in the figure 1. Firstly I created a block and made it periodic. Then I made a two horizontal split (along y-axis), one in the front of the blade and other behind the blade. And I also made two vertical split (along x-axis), one in the suction side and other in the pressure side. Then I inserted a O-block and merged the vertex in the trailing edge and converted into C-block. Then I associated the edges to the curves of the airfoil section of the propeller blade. Figure 2 shows the block details. I made several split along the span of the propeller blade and associated the edges as I said previously. I got a nice mesh with good quality.
Actually I want to do optimization so I am going to automatize the meshing process. When I change the twist angle along the span of the blade, I get high skew cells near the blade region as shown in the figure 3. I am going to change the twist angle continuously during the optimization process. So this blocking strategy doesn't work.
I heard of shifted periodic blocking strategy will fine for the highly twisted blade. I have seen several posts about the shifted periodic block but I really don’t know how to do it and I don’t know how I can apply the shifted periodic for my propeller blade.
I need a blocking like figure 4. But I dont know how to get that. Please help me to construct such blocking strategy. I have attached the tin and block file. Please help me.
https://www.dropbox.com/sh/jkl3dqoaf...ont_domain.tin
https://www.dropbox.com/sh/jkl3dqoaf...ont_domain.blk
https://www.dropbox.com/sh/jkl3dqoaf...ont_domain.prj
venkat_aero2007 is offline   Reply With Quote
Old   August 14, 2013, 11:50
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Dear venkatesh,
This is a pretty interesting problem that surely needs a lot of ingenuity during blocking. By the way, I couldn't see the attached image that you posted in the other thread. I have not meshed anything like that but I can try to help you. Let me take a look at the geometry and blocking files that you just posted and I'll let you know if I find a way to tackle this problem.
Regards,
César
cesarcg is offline   Reply With Quote
Old   August 15, 2013, 08:43
venkatesh
Dear cesarcg,
Thanks for your reply. I am struggling a lot to mesh this geometry.
I have uploaded the images of the thread
Shifted Periodic topology
Regards,
venkatesh
Old   August 15, 2013, 09:07
venkatesh
Dear cesarcg,
Please have a look on the below post, I have already generated a mesh with the help of Far.
Quarter O-grid topology for propeller blade
But In this current post, I want to generate mesh with shifted periodic topology.
waiting eagerly for your suggestion.
Regards,
venkatesh
Old   August 16, 2013, 19:08
Cesar
I have seen your geometry and blocking files. It is difficult for me to start from the 3D model. I think it would be easier to start by proposing the strategy for a 2D model and then, based on that, propose a strategy to mesh the 3D model. Let me know if you can generate a 2D model using the aerodynamic profile that you are using at the root of the rotor.
Regards,
César
M MOHSIN likes this.
Old   January 5, 2014, 06:06
Post Help in cfd plz
M MOHSIN's Avatar
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
M MOHSIN is on a distinguished road
I am new to cfd i hav to do a project on propeller simulation . can any body help me plz in this regard . . . . . awaiting
M MOHSIN is offline   Reply With Quote
Old   January 5, 2014, 11:45
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
For quick simulation you can use Prism+tetra. However hexa will give you good results but will take some time to learn...
Far is offline   Reply With Quote
second order schemes marine OpenFOAM 67 April 11, 2022 18:19
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
multiphaseInterFoam: timestep error by simulating a co-extrusion nozzle Quatschinsky OpenFOAM Running, Solving & CFD 7 March 27, 2014 05:08
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 10:44
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
