[ICEM] Propeller blade-Shifted periodic or J-Type BLOCK |
August 9, 2013, 05:50 |
venkatesh
Rep Power: 13 |
Hi
I am trying to mesh a propeller blade. I tried to mesh the propeller blade just like the wing. The propeller geometry is shown in the figure 1. Firstly I created a block and made it periodic. Then I made a two horizontal split (along y-axis), one in the front of the blade and other behind the blade. And I also made two vertical split (along x-axis), one in the suction side and other in the pressure side. Then I inserted a O-block and merged the vertex in the trailing edge and converted into C-block. Then I associated the edges to the curves of the airfoil section of the propeller blade. Figure 2 shows the block details. I made several split along the span of the propeller blade and associated the edges as I said previously. I got a nice mesh with good quality. Actually I want to do optimization so I am going to automatize the meshing process. When I change the twist angle along the span of the blade, I get high skew cells near the blade region as shown in the figure 3. I am going to change the twist angle continuously during the optimization process. So this blocking strategy doesn't work. I heard of shifted periodic blocking strategy will fine for the highly twisted blade. I have seen several posts about the shifted periodic block but I really don’t know how to do it and I don’t know how I can apply the shifted periodic for my propeller blade. I need a blocking like figure 4. But I dont know how to get that. Please help me to construct such blocking strategy. I have attached the tin and block file. Please help me. https://www.dropbox.com/sh/jkl3dqoaf...ont_domain.tin https://www.dropbox.com/sh/jkl3dqoaf...ont_domain.blk https://www.dropbox.com/sh/jkl3dqoaf...ont_domain.prj |
August 14, 2013, 11:50 |
Dear venkatesh,
This is a pretty interesting problem that surely needs a lot of ingenuity during blocking. By the way, I couldn't see the attached image that you posted in the other thread. I have not meshed anything like that but I can try to help you. Let me take a look at the geometry and blocking files that you just posted and I'll let you know if I find a way to tackle this problem. Regards, César |
August 15, 2013, 08:43 |
venkatesh
Rep Power: 13 |
Dear cesarcg,
Thanks for your reply. I am struggling a lot to mesh this geometry. I have uploaded the images of the thread Shifted Periodic topology Regards, venkatesh |
August 15, 2013, 09:07 |
venkatesh
Rep Power: 13 |
Dear cesarcg,
Please have a look on the below post, I have already generated a mesh with the help of Far. Quarter O-grid topology for propeller blade But In this current post, I want to generate mesh with shifted periodic topology. waiting eagerly for your suggestion. Regards, venkatesh |
August 16, 2013, 19:08 |
I have seen your geometry and blocking files. It is difficult for me to start from the 3D model. I think it would be easier to start by proposing the strategy for a 2D model and then, based on that, propose a strategy to mesh the 3D model. Let me know if you can generate a 2D model using the aerodynamic profile that you are using at the root of the rotor.
Regards, César |
January 5, 2014, 06:06 |
Help in cfd plz
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
Rep Power: 12 |
I am new to cfd i hav to do a project on propeller simulation . can any body help me plz in this regard . . . . . awaiting
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 18:19 |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
multiphaseInterFoam: timestep error by simulating a co-extrusion nozzle | Quatschinsky | OpenFOAM Running, Solving & CFD | 7 | March 27, 2014 05:08 |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 10:44 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
