January 25, 2014, 09:54 |
Periodicity Setting ICEM for CFX
Hi all,
I am facing problems when importing my ICEM mesh to CFX. (14.0) In ICEM I wanted to mesh a third of a tube to take advantage of its symmetry. So I used "Global Mesh Parameters -> Set Up Periodicity" and chose the values for "Base", "Axis 0 0 1" and "Angle 120". Computing Mesh causes no problems also regarding the Boundary Layers I added. As usual I exported the mesh as *.cfx5 and imported it in CFX. (See Screenshot below) As you can see the Prism Layer is not connected anymore to the Fluid Region. Also a new Region was "randomly" created in CFX-Pre named "CARTFACES".
The Symmetry Planes were reduced to the part of the Boundary Layer. I think I miss some steps in ICEM before writing the *.cfx5 file. Could someone please give me a hint? Thanks in advace, Julien |
[ICEM] How define periodicity correctly in ICEM | FJSJ | ANSYS Meshing & Geometry | 18 | January 11, 2023 11:07 |
[ICEM] ICEM periodicity specification | robboflea | ANSYS Meshing & Geometry | 18 | November 11, 2014 14:51 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
