February 14, 2014, 09:42 |
Internal Error in ICEM
Rep Power: 13 |
Hi
I am new to ICEM and I am now learning ICEM by going through the 2d pipe junction tutorial. When I tried to change the split method, the following error occurred. An internal error has occured: bad geometry specifier "241x74+1456189" You can report the error to the maintainers of this software, skip the error and continue working, or view a stack trace. I tried to click on continue but the same error message appeared again when I tried to change the split method. Does anyone can advise me on this matter? |
July 10, 2014, 04:06 |
Rep Power: 14 |
I have the same problem ... don't know where it comes from ...
April 28, 2015, 10:27 |
robert kulhanek
Rep Power: 15 |
Do you use 2 monitors? Does this happend when you try activate rolling menu? Try this on second screen...
This helps to me Robert |
April 29, 2015, 05:05 |
Rep Power: 13 |
Hi. The posting was about a year ago and if I remember correctly, the problem was caused by using two monitors as you said. It seems that it is purely the bugs.
[ICEM] ICEM CFD internal Wall by using structured Grid | challenger85 | ANSYS Meshing & Geometry | 17 | January 26, 2017 13:04 |
Fire FAME Hexa or Ansys Icem for Internal Nozzle Flow | Doofy | Mesh Generation & Pre-Processing | 0 | March 18, 2013 06:24 |
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface | James Date | CFX | 3 | August 10, 2012 04:47 |
an internal error occurre in ICEM | qiulan | ANSYS Meshing & Geometry | 2 | September 22, 2010 10:14 |
ICEM CFD - minor internal error, number of nodes don't match | Anorky | ANSYS Meshing & Geometry | 0 | June 4, 2009 10:41 |
