[ANSYS Meshing] Meshing of bullet farfield (via inflation)
Old   February 19, 2014, 04:00
Default Meshing of bullet farfield (via inflation)
Hernus
Hernus is on a distinguished road
Hallo,
I'm currently investigating in the Aerodynamics of a flying bullet. I'm quite comfortable with the set-up I use.
The bullet analysis is for speeds up to 3 Mach, attack angles up to 6 degrees, and a rotational bullet (wall) of up to 22 000 rad/s.
The results I get is almost acceptable, except the force in z direction and moment around y-axis on the centre point of bullet (Magnus force and Magnus moment). These values jump around a lot and never converged to the same value even if the same conditions is run again.
I have a feeling this is about the mesh, I'm currently just using the meshing system inside ANSYS with just the default inflation from the body towards a greater outfield. I tried to refine the mesh around the bullet and inflate more and more gradually with extensive bodies but with no luck. when I ran the simulation in Fluent I get an "Floating point f" error. I really tried a lot of different meshing techniques with no luck
I also know the "floating point f" error can be because of lost units...
Is there anyone that maybe can assist me in the mesh?
Thank you
hernus.groenewald@gmail.com
Hernus is offline   Reply With Quote
bullet, farfield, fluent, inflation, mesh
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem dalecooper ANSYS Meshing & Geometry 0 July 19, 2013 07:04
[ANSYS Meshing] Hexa Meshing with inflation AS_Aero ANSYS Meshing & Geometry 0 April 15, 2013 10:41
[ANSYS Meshing] Unwanted bias while meshing a tube with sweep and inflation rasko ANSYS Meshing & Geometry 7 July 23, 2012 10:31
Meshing inflation guidelines mauricio CFX 7 August 26, 2011 06:36
ANSYS Meshing: Structured Mesh with Inflation Antanas ANSYS Meshing & Geometry 1 June 18, 2011 20:23
