[ICEM] Convert two prism blocks into a hex block
Old   February 26, 2014, 10:59
Default Convert two prism blocks into a hex block
newbie384 is on a distinguished road
Hi
Can someone advise me on how to convert the two prism blocks (5 faces each) into a single hex block, as shown in the picture? I tried merge block but nothing seems to change even though "merge blocks done" message appear in the log window.
newbie384 is offline   Reply With Quote
Old   February 26, 2014, 12:35
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
go to blocking > edit block > set type > y block
Do above procedure for both blocks.
Far is offline   Reply With Quote
Old   February 26, 2014, 16:07
Thank you so much. It works!
[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face A.A. OpenFOAM Meshing & Mesh Conversion 41 June 26, 2020 07:06
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
