[DesignModeler] simply model, empty box
Old   March 28, 2014, 18:26
Default simply model, empty box
dino sama
conquer is on a distinguished road
Hello everybody, I have simply problem..I need to create a empty box with thickness of walls 30 mm, Box have dimensions 0,5 m x 0,5 m x 0,5 m. I do this steps:
1. I create box, with earlier dimensions
2. with tool Thin/surface I set thickness of walls 30 mm
3. then I hide surfaces on side for next step
4. and then with tool "fill" I select interior surfaces of box to fill that volume inside box
, and I have now solid (box), and fluid inside box
Problem is in meshing, because there is no contact between meshes of fluid region and solid part. I do some on changing meshing method and similar, but helpless. I need this model for thermal analysis. I will be very appreciative for any suggestion. and sorry for poor english
King regards
conquer is offline   Reply With Quote
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
how to model glass wool containing in a box kumar Siemens 0 September 29, 2008 12:06
New turbulence model - CEL or Junction Box? flga CFX 3 October 31, 2006 03:04
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 21:20
