April 7, 2014, 10:05 |
Sharp angle warning
fariba k.
Rep Power: 12 |
Hi everybody. When I tied free meshing for my model, I got this error:
"Sharp angle warning: Triangle facet defined at area 419 form an angle of 1.4 degrees with facet at area 387” So it causes VMESH failure. Is there any idea about this error? |
April 9, 2014, 06:30 |
Bharath kumar
Rep Power: 17 |
Which mesher you are using ,Is it ICEM CFD?
Clean up your geometry before meshing. |
April 11, 2014, 02:25 |
fariba k.
Rep Power: 12 |
mentioned problem was for APDL, I think it's better to do meshing in CDF. Is it possible to import CDF mesh to APDL for simulation? If so, which format? thanks alot
April 11, 2014, 02:27 |
fariba k.
Rep Power: 12 |
Can you explain how can I clean up my model? my model is based on MRI scans so there is so much complexity in the model.
April 15, 2014, 01:03 |
Bharath kumar
Rep Power: 17 |
Hi Fariba
I think you are new to this. Try Ansys workbench meshing.Please do some tutorials before starting meshing. |
April 15, 2014, 03:16 |
fariba k.
Rep Power: 12 |
yes, I am new in ansys. thanks for solution. Is there any method to transport my geometry and material properties to workbench for meshing?
April 15, 2014, 23:55 |
Bharath kumar
Rep Power: 17 |
Import is same as you are doing in other ansys packages.
Try workbench help for more information. |
vmesh failure |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
