[ICEM] mesh size limitation due to hardware!
Old   April 9, 2014, 07:38
Default mesh size limitation due to hardware!
mariachi is on a distinguished road
Hi Dear All,
I was wondering if anybody could tell me how to guess/predict the upper limit for a mesh that can be generated on a given PC?
To explain it further,
1. System 'A' is Intel(R) Core(TM) i7-2600 CPU @ 3.40 GHz 3.40 GHz with 16.0 GB of RAM.
2. System 'B' is Intel(R) Xeon(R) CPU E5520 @ 2.27 GHz 2.27 GHZ (2 processors) with 24.0 GB of RAM.
What is the max mesh size that can be grown on both these systems???
Or is it that there is no such limitation posed by hardware except that the mesh generation time will increase on a low specs system and thats all!
Thanking in advance!
mariachi is offline   Reply With Quote
Old   April 10, 2014, 02:33
Or is it that there is no such limitation posed by hardware?
I mean the mesh will get generated, no matter how big or small, but time will vary!
Correct me if im wrong plzzz...
Old   April 12, 2014, 23:57
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
On 4 GB system with windows 7 64 bit, I am able to generate 10 Million + nodes. So I guess for 16 GB RAM you have generate 40 million + nodes easily. For such sizes you may expect couple of hours to get the mesh.
Far is offline   Reply With Quote
Old   April 16, 2014, 02:47
Thumbs up
Thanks Far, for sharing your experience !
Yes you are right, it does take a couple of hours to generate a mesh this big. So ill see how much bigger mesh can i generate with my available resources
[snappyHexMesh] Is the changing on size of baground mesh of blockMesh; effect on the SHM result? s.m OpenFOAM Meshing & Mesh Conversion 0 October 12, 2013 09:57
Importing an OpenFOAM mesh into Engrid. Is there a mesh size limitation ? ayoros enGrid 0 April 20, 2011 09:53
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
