meshing problem
1 Attachment(s)
hello all..
i am facing problem in creating geometry...my problem includes a rectangle with one vertical baffle inside..initially i am creating a solid body and then using new plane i am creating surface body inside it as baffle. the i am creating 1 part 2 bodies,but when i export it to meshing,there only solid is showing under geometry tree...not able to understand what to do..plz help me...:mad: Attachment 30276 |
You can have 2 parts in DM (body + surface) but if you want to mesh your 3D body with a 2D surface mesh "inside" that doesn't cover the whole 3D geometry then you have a problem. What exactly do you want to study? |
thanks for your reply. i want to simulate sloshing problem inside rectangular tank with and without baffles.
