[ICEM] ICEM problem when doing not so fine mesh
Old   April 30, 2014, 16:59
Default ICEM problem when doing not so fine mesh
Luiz Eduardo
DudaAPD is on a distinguished road
I am having the following problem with ICEM:
Geometry is simple --> Rectangle 200x0,06191 (x,y) with an inlet and outlet at the x direction, a wall and an axis.
When I have a number of nodes at the x direction Nx=32300 and on the y direction Ny=50, I have an aspect ratio of dx/dy=5 (orthogonal mesh). Untill here, no problem at all.
I want to do a finer mesh with a dx/dy=2.5 without changing Ny (50). For this, I need to have Nx=64600. However, here is where the problem is. ICEM doesn't show the mesh when I press "pre-mesh". It shows "Done recompute", but nothing happens. I save the project and do Mesh->load from blocking and the attached error message appears.
If I keep Ny=50 and Nx=32750, it is still working. If I change Nx=32800 it stops working.
If I change Ny=60, I am also limited around Nx=32750...
Any help is much appreciated.
Thank you in advance,
Duda
DudaAPD is offline   Reply With Quote
[ICEM] 2D ICEM Mesh Problem adamz1 ANSYS Meshing & Geometry 4 February 11, 2013 09:20
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 03:54
[ICEM] Problem with ICEM generated Mesh geothokar ANSYS Meshing & Geometry 3 May 11, 2009 13:26
