[ICEM] Association in ICEM
Old   May 7, 2014, 05:58
Default Association in ICEM
itsme_kit is on a distinguished road
Hi
If I got a cube as a geometry and I created a block, is association a compulsory step for this geometry?
I think we only need to edit the edge parameters, right?
Thanks for your explanation
itsme_kit is offline   Reply With Quote
Old   May 7, 2014, 06:30
Javi
FJSJ is on a distinguished road
Hi Ke Wu,
If you want avoid problems when you read your mesh in a solver, you should associate edge to curve.
FJSJ is offline   Reply With Quote
Old   May 7, 2014, 09:47
Originally Posted by FJSJ View Post
Hi Ke Wu,
Thanks Javi
Old   May 12, 2014, 17:09
Sebastian Engel
bluebase will become famous soon enough
By associating edges boundary elements (e.g. line and quadrilateral elements) will be created while premeshing. Most solver probably need seperate sets of boundary elements.
I think that for a 3d block geometry the association of the corner points with the vertices might be enough, too.
bluebase is offline   Reply With Quote
Old   May 13, 2014, 04:07
Actually I didn't do association and just edited edge parameters, then premesh
I checked the mesh in Fluent, no error turned up
Edges association in ICEM Santiago Orrego. CFX 10 July 26, 2020 11:45
Edge association in ICEM CFD for compressor flow passage- Need help! supermanks ANSYS 1 February 19, 2014 00:39
[ICEM] Different meshes from ICEM and GAMBIT Mojtaba.a ANSYS Meshing & Geometry 9 March 30, 2013 02:42
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
