ICEM CFD Replay File Error - Help Needed
I am running ICEM CFD on Linux and I am trying to open the replay file via command line terminal. My replay file is in the correct directory as I am able to load it when using GUI.
So I just wrote: icemcfd geoRepair_juzer.rpl And I am getting the following error: couldn't read file "geoRepair_juzer.rpl": no such file or directory while executing "source geoRepair_juzer.rpl" invoked from within "script_interp eval [list source $file]" (".rpl" arm line 2) invoked from within "switch [file extension $file] { .prj - .wbpj { aie_openProject $file } .tin { aie_open_geom 1 [list $file] } .uns { aie_open_Mesh 1 "" ..." (procedure "aie_openFile" line 3) invoked from within "aie_openFile $f " (procedure "AIEnvMain" line 432) invoked from within "AIEnvMain" (file "/usr/local/ansys_inc/v145/icemcfd/linux64_amd/lib/ai_env/init.tcl" line 1878) invoked from within "source [file join $env(ICEM_ACN) lib ai_env init.tcl]" invoked from within "if {[info exists env(ICEM_AI_ENVIRONMENT)] == 1} { if { $env(ICEM_AI_ENVIRONMENT) == 1 } { if {[info exists env(MED_ROOT)] && ..." (file "/usr/local/ansys_inc/v145/icemcfd/linux64_amd/lib/med/med_start.tcl" line 27) invoked from within "source $med_root/lib/med/med_start.tcl" invoked from within "if [file exists $med_root/lib/med/med_start.tcl] { source $med_root/lib/med/med_start.tcl } elseif [file exists $med_root/../med/lib/med/med_start..." PLEASE HELP ME SORT OUT THIS ISSUE |
