May 26, 2014, 10:40 |
Import mesh from TurboGrid into ICEM
Daniel Frederik
Rep Power: 11 |
Hi everybody,
I tryed to export the mesh in TurboGrid and then load it in ICEM. Somehow that doesn't work. In TurboGrid i can not find the right export files. I need that cause i want to put the different meshes in the right place with eachother and that would work well if i had them together in ICEM, and after transform the meshes correctly load them seperately in CFX-Pre. Does anybody have an idea? Thank you Daniel |
May 27, 2014, 04:39 |
mesh
tmeysam92
Rep Power: 14 |
did you try the cgns format. i import mesh in cgns format from turbo grid to icem cfd, then from icem cfd you can save mesh in .msh format.
May 28, 2014, 05:52 |
Daniel Frederik
Rep Power: 11 |
Thank you very much for your reply. I tryed CGNS didnt work though, don't know why. I found another soution to my problem.
Display Modes | |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
Gambit mesh file import into ICEM CFD | dev.... | FLUENT | 2 | January 29, 2009 11:37 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 07:46 |
