July 2, 2012, 07:00 |
cylinder structured mesh
masood
Rep Power: 13 |
hi .
how can i generate a mesh like this in gambit ?? i dont know how to add nodes to have such a mesh !! any help or tutorial appreciated . |
July 2, 2012, 07:21 |
Maxime Perelli
Rep Power: 41 |
on your first picture you can see a square at center from disk.
Let assume you only have the disk (2d) the decomposition will be a square and then join corners from square to the circle (you need to split the circle with some points) Sans titre.jpg
In memory of my friend Hervé: CFD engineer & freerider |
July 2, 2012, 09:05 |
#3 | |
masood
Rep Power: 13 |
July 30, 2012, 16:11 |
zainab
Rep Power: 14 |
hi
I have the same problem. please, if you get any solution tell me. |
July 31, 2012, 04:13 |
#5 | |
masood
Rep Power: 13 |
hi zeinab . while in gambit draw a cylinder then split it into 4 equal parts , make a cube at center of cylinder , subtract cube from the cylindrical parts now use volume mesh >>hex/map remember to connect the faces . u can do this in 2d or 3d |
August 1, 2012, 10:20 |
zainab
Rep Power: 14 |
Hi Masood, thank you for your help
I working as you tell me, finally i get a five meshed domains, when I wont to export the mesh to FLUENT , must unite all the volumes to be one cylindrical volume to specify the regions, inlet, outlet, etc. when I do this step the mesh deleted. what can I do |
August 1, 2012, 10:55 |
No need to unite them. Go to boundary condition panel and select all five faces on one side as inlet and corresponding five faces at other side as outlet. Similarly for the outer wall of the cylinder
October 9, 2012, 10:01 |
please see the picture and help me
#8 | |
wesam
Rep Power: 13 |
i need the steps to make a mesh like in pic by gambit . please i need help |
October 10, 2012, 05:52 |
#9 |
Tamil Nadu
Rep Power: 13 |
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT. Can anybody help me out, how to model and simulate? Does any tutorials exist? |
May 27, 2014, 01:26 |
#10 |
shahrbanoo
Rep Power: 13 |
Hi
I made this mesh on 2d circle, but when I change it to 3d mesh I have negative volume . how can I make it better not to have negative volume? and why I have them? |
May 27, 2014, 03:31 |
#11 |
Maxime Perelli
Rep Power: 41 |
display your geometry
Display Modes | |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
3-d mesh gambit (cylinder within a cylinder) | Jason | ANSYS Meshing & Geometry | 29 | October 30, 2015 08:59 |
Ugly mesh around cylinder | rks171 | STAR-CCM+ | 4 | May 9, 2012 14:35 |
[ANSYS Meshing] Mixing structured with unstructed mesh | hadrien51 | ANSYS Meshing & Geometry | 0 | February 22, 2012 05:17 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
