[ICEM] ICEM > Fluent, boundary conditions are not showing up |
April 25, 2016, 14:42 |
Sean
Hello, I'm working on my final year project and I'm attempting to do abit of CFD.
I'm having an absolute nightmare, I am attempting to simulate a multiphase flow between oil and water in a microfluidic channel to back up a decision I made in my project. My boundary conditions do not seem to be translating over to FLUENT. My process has been: Create geometry in solidworks Map out Wall, oil inlet, water inlet, outlet as seperate parts (ive used the line tool). Create blocking Mesh Save as unstructured mesh Set boundary conditions, Oil > velocity inflow, Water > velocity inflow, Outlet > outflow, Wall > wall But when I open in FLUENT all that appears is "int_part_1", "wall_part_1" My thesis is due on friday so any help would be MUCH appreciated. Please keep it simple if possible as im pretty new to this stuff. |
April 26, 2016, 04:34 |
Rep Power: 10 |
Could you please try to give boundary conditions at OUTPUT section and same section get output for fluent. Morever, you should always save your project when ICEM asks. If you were not doing that, that would be the reason.
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
