June 16, 2014, 09:41 |
CGNS output question
Ernesto
Rep Power: 14 |
Sorry to bother, I've got a question regarding cgns: I've created a (volume) mesh by extruding a surface mesh along a curve. In order to do so I had to convert the 2D surface block to unstructured. The problem is that I want a structured cgns output. I've tried first converting the 2D surface mesh to multiblock but then I can not extrude the surface mesh. The workaround would be to create the mesh by using a 3D block but I can not get a good quality mesh that way. My geometry is a 3D 90 degree pipe bend. I've completed a very similar tutorial (hexa mesh generation for an elbow part) but it is very difficult to set the correct associations in order to get a good quality mesh in my case. What would be your suggestion to cope with this problem? Thanks in advance |
June 18, 2014, 02:09 |
Ovi
Rep Power: 13 |
Please post some images so that everyone can visualise the problem and whether it is some obvious problem with the geometry or blocking.
Thanks.
-- Mechanical Engineering Sydney, Australia |
June 18, 2014, 08:47 |
Ernesto
Rep Power: 14 |
Edit: I already solved this problem. As I said before I needed a 3D block in order to export the mesh as a structured file. I've found the correct 3D blocking strategy.
Thanks |
Changing Polynomial Properties of species from 8 to 16 coefficients | Kenna | OpenFOAM Programming & Development | 1 | November 20, 2013 03:44 |
CFD output question | Moonlighter | Main CFD Forum | 2 | December 21, 2009 14:29 |
Output transient file to csv | Ben | CFX | 3 | September 23, 2008 08:17 |
can "output control " output Nu in expression? | prayskyer | CFX | 3 | July 7, 2006 19:37 |
Help with DPM UDF for OUTPUT needed | Zhengcai Ye | FLUENT | 0 | January 5, 2004 16:58 |
