[ANSYS Meshing] "Multibody Part" doesn't apply to Fluent?
Like Tree1Likes
  • 1 Post By jsm
Old   December 7, 2011, 12:00
Question "Multibody Part" doesn't apply to Fluent?
Alex R.
J_Alex is on a distinguished road
Hey everyone,
I'm having some problems with ANSYS Meshing Tool in WB - well, at least I think that is what the problem is based on.
Generally, I'm trying to simulate a combination of internal and external flows (quite complex geometry) in FLUENT.
My fluid domain consists of several fluid bodies (12 solids all in all) which should all share faces with the adjacent cell zones so that i don't need to define interfaces manually in Fluent afterwards.
Some of the bodies shall be implemented as porous zones and I would like to include a FAN-BC into the model in FLUENT.
I simplyfied my geometry in CATIA V5 and imported the bodies into Design Modeler via iges-files.
Although I included all of the bodies in one single part and the overall shared topology tool seems to work - Fluent doesn't connect the cell zones and decides to create walls where the cell zones meet.
How can I change that? Is that a problem in Design Modeler, Meshing or Fluent?
As i don't know how to approach that problem in Ansys Meshing I tried I already tried a couple of other things:
  • Via the "Fuse Faces" tool in FLUENT I create some bigger holes in my desired contact area as several faces of my mesh seem to be missing then - although the mesh of the two cell zones seem to be identical at that very face
  • When changing the WALLs to INTERFACEs via Named Selections in Ansys Meshing and coupling them in FLUENT I don't know how to create a FAN boundary condition
Any ideas? I would appreciate your help very much!
Cheers
J_Alex is offline   Reply With Quote
Old   December 12, 2011, 09:04
jsm
JSM
jsm is on a distinguished road
Hi
From your message, I think that you got non conformal mesh between bodies.
You need to create part to get the conformal mesh.
To create the part, select all bodies in tree, right click to get the form new part option.
Update the mesh in ansys meshing. You will get conformal mesh.
fanaticreader95 likes this.
With regards,
JSM
jsm is offline   Reply With Quote
Old   December 12, 2011, 09:36
Alex R.
Hi jsm,
thank you for your reply but in the meantime I have resolved the problem somehow.
Stangely, it didn't have to do anything with creating a multibody part (which i have done in that case but without any success) - but with the way I created my fluid domain in general.
First, I created one single fluid domain which I then split up into subdomains via boolean operations (substract imported "internal" fluid domains) - and somehow Ansys Meshing didn't really like that.
When i tried it the second time, I first imported my "internal" fluid domain and applied an enclosure with a self-defined geometry around it as my "external" flow domain.
Everything worked out like that but i still don't understand why it didn't work the first time.
Cheers,
Alex
Old   June 18, 2014, 16:15
AZ
mjthomp3 is on a distinguished road
I have the same problem but your solution doesn't fix it for me.....
mjthomp3 is offline   Reply With Quote
cell zones, complex profile, interfaces, multibody part, shared topology
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 6, 2018 23:37
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
