[ANSYS Meshing] Problem in Meshing a tube in tube Helical HX
Old   August 4, 2014, 07:50
Default Problem in Meshing a tube in tube Helical HX
Maradona
Maradona is on a distinguished road
I have been modelling an tube in tube helical coil heat exchanger with hot fluid at inner tube and cold fluid at outter tube.Since it involves both solid and fluid zones the meshing seems difficult and doesn't match well.
I have meshed the model and obtained 556856 nodes and 383435 elements but while analysing i cant get the proper results.
Is there any specific kind of meshing needed to be done for these kind of problems kindly suggest me a solution
Maradona is offline   Reply With Quote
Helical Coiled Tube - Sample data in cut planes deandrade OpenFOAM Post-Processing 1 April 11, 2013 14:15
[ANSYS Meshing] 2-Way FSI meshing problem using ANSYS 13 workbench john881129 ANSYS Meshing & Geometry 0 January 9, 2012 01:19
Shock Tube problem mouna lamnaouer FLUENT 1 September 22, 2011 12:47
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
